Page 68 - MetalForming October 2017
P. 68
Previews
Anticorrosion Packaging
HTM Sensors will show its Spotlight technology for identifying the inputs within a plant causing downtime. The technology shows on the HMI screen exactly where the input is found so that a solution can be deployed to replace the product, change the location, or increase protection of the input.
robotic weld cells. The analytic software knows the cycle time of a good part, and if there is downtime because of a particular input. The amount of time and events count are traced to the input level for analysis and investigation.
www.htmsensors.com
Press-to-Press
Transfer Technology
Oriimec Corp. of America Booth A5048
Daubert Cromwell Booth A4917
Daubert Cromwell will exhibit its volatile corrosion inhibitor (VCI) packaging for pro- tecting metal parts during storage and shipment. Representatives will explain
SOLUTIONS FOR QUICK DIE CHANGE
CLAMPS DIE TABLES DIE TRANSFER
how VCI papers, films, bags and liquids work to prevent corrosion on metal parts in all phases, from production to export. They also will demonstrate water-based rust-removing liquids on ferrous metal parts. Visitors will see a typical metal- parts bin lined with a VCI polybag and VCI paper interleaving between layers of metal components. The interactive display will show proper use of anticorrosion packaging to wrap and store valuable materials. www.daubertcromwell.com
Spotlight on Troubleshooting
HTM Sensors, Inc. Booth A5285
Spotlight is designed for use with
Booth A5307
• Die carts on rails
• Double die carts
• Dieposi oners
• Custom die change systems
• Clamps- roller bars
• Bolster extensions
Hydraulic roller bars
Dual push-pull
Oriimec will demonstrate a robotic transfer line with de-stacking system: three ORII press-to-press transfer robots, two presses and a stacking system. The RHQ transfer robot uses two-axis, servo- driven technology to improve speeds and accuracy. Also, the RHQ robot will syn- chronize with the presses’ crank motion to maximize strokes-per-minute processing time. The transfer robot line will be show- cased with Komatsu presses.
www.oriimec.com
Clamps
SERAPID | +1 (586) 274-0774 | info-us@serapid.com | www.serapid.com
66 MetalForming/October 2017
