Page 70 - MetalForming October 2017
P. 70
Precise
Previews
Airless
Spr
L
S
ay
Guarding Solutions
Booth A5263
Lazer Safe Pty. Ltd. Booths A3109
Lazer Safe will show its Sentinel Plus guarding system for press-brake retrofit applications and the FoldGuard guarding system for long folding machines.
dis
The Sentinel Plus sys-
tem uses BendShield safe-
ty technology to automat-
ically scan the upper tool
profile and adjust its safety
zone to envelop the tool
tip with a protective field
that has no gaps, keeping
operators safe while oper-
ating the machine at high
speed. Its RapidBend Plus
technology uses a patent-
ed progressive muting process that enables press brakes to close safely at high speed until the punch locates just 2 mm above the workpiece.
place
me
nt pump
st
o dis
pe
ns
e
It’
aneo
saf
, non-fo
us
og
as
t
g
ng
i
, ins
t
ant
handle heavy v
Bystronic, Inc. Booth A1819
i
i
y lub
s
c
s as
os
t
r
ant
The FoldGuard provides optical protection for the clamping operation, monitoring of machine performance, and management of additional machine safety elements. Its laser transmitter and receiver are positioned on either side of the machine with floor-mounted brackets, and a continuous laser field protects the zone between the clamp to protect the operator. If an obstruction is detected, the clamp motion is automatically stopped. Lazer Safe’s Fold Guard dealer, AMS Controls, Inc., will
ic
Bystronic will showcase a range of equipment and software advance- ments. Among them:
demonstrate the system at booth C41040.
www.lazersafe.com
Fabricating Innovations
p: 815-226-8
• 10-kW ByStar 3015 fiber laser demonstrated with the ByTrans Extended automated material-loading/unloading system.
f
8090 9250
:8
• Manufacturing Execution System (MES) software for creating digital transparency across the entire process chain.
15-
226-
• BySoft 7 software.
• Xpert 40 Mobile Bending Cell, a compact solution for automated and manual bending that supports fluctuating lot sizes and varying part complexities.
• Xpert 80 press brake for bending complex, small and medium-sized parts.
• Xact Smart 160 press brake, with a five-axis backgauge and extend- ed open height.
• Xpert 150 press brake, with integrated six-axis robotic tool changer, which can reduce setup time by 70 percent.
• ByCockpit software, which analyzes and visualizes the process data associated with sheetmetal production. www.bystronicusa.com
68
MetalForming/October 2017
