Page 12 - MetalForming November 2017
        P. 12
New Encoder Capability for Motion Controller
With the capacity to tightly synchronize as many as 32 motion axes, a single RMC200 can manage the motion of large testing or manufacturing applications. As with tother Delta controllers, including the RMC75, which can control one or two axes, and the RMC150, which can control as many as eight axes, the RMC200 has many special features including electronic gearing and position-pressure/force-control capabilities. Delta Computer Systems, Inc.: www.deltamotion.com
Delta Computer Systems, Inc., Battle Ground, WA, has introduced the Q4 quadrature encoder input module for its RMC200 motion controller. The RMC200, which handles as many as 32 axes, is the newest member of the company’s RMC family of closed-loop
electro-hydraulic motion controllers.
Each Q4 module has four incremental quadrature
encoder input channels supporting RS-422, HTL or TTL digital-signaling standards. Each input channel also has home and registration inputs with 5- or 24-V signal levels and LEDs indicating encoder faults and the state of the home and registration inputs.
Other RMC200 modules include synchronous-ser- ial-interface (SSI) input, high-performance 18-bit analog and configurable discrete I/O. For flexibility in new and retrofit applications, the SSI module can be con- figured to handle one RS422 Q4 input, and the discrete I/O module can handle a 5- to 24-V quadrature encoder, including one with open-collector outputs. The new
EDM for Large Molds
Q4 module, like all modules in the RMC family, use Delta’s RMCTools software for setup, tuning, programming and diagnostics.
Sodick, Inc. announces its VL600HQ wire EDM. With a 500-mm Z-axis stroke, the new high-column model is designed to accommodate a wider variety of large workpieces, making it ideal for large molds as well as automotive and aerospace appli- cations. It offers an improvement to the company’s SuperJet Automatic Wire Threader
“Our customers increasingly desire more flexibility with the many axes that the RMC200 can control,” says Steve Nylund, Delta Computer Systems CEO.
    Lightweight Solutions
For the Manufacturing Industry
How can DESTACO help
Accelerate Your Productivity
DESTACO has been at the forefront of offering flexible end effector solutions, developing
a wide range of products designed to help customers speed up their production lines.
• Automatic and Manual Tool Changers
•   Accelerate® Lightweight Tooling Systems
• Accelerate® Polyurethane Vacuum Cups
• Accelerate® Sheet Metal Press Shop Grippers
• ARV® Auto Release Venturi with Manual Release
Precision in ProductivityTM
destaco.com
        Contact us at 888-DESTACO or visit our website
                       End Effectors | Grippers | Indexers | Manual Clamps | Power Clamps | Remote Handling
                    10 MetalForming/November 2017
