Page 56 - MetalForming-Jan-2018-issue
P. 56
Our Air Feeds are:
An exceptional value Versatile
Simple to install
Easy to operate Mount directly on dies
So cost-effective, it justifies permanent installation on each die set
Minimize job setup time
Reduce cost of production
Faster material flow speeds
Uniform accurate progressions
Low air consumption Quiet operation Lasting performance
THE WORLD’S
FEEDING & COIL HANDLING EQUIPMENT OF FIRST CHOICE
Rapid-Air pioneered and innovated the first compact air feed. Still the leader today, this proven high quality equipment is now offered by an expanded network of Europe’s leading press room equipment dealers. Rapid-Air feeds are the preferred choice
to handle metal, wire, plastic, fabric; you name it - in most any shape. Why settle for anything less?
Ask about our comprehensive range of reliable air feeds, servos, straighteners, cut-to-length machines and reels, all supported by local dealers committed to your success.
RAPID-AIR
4601 Kishwaukee Street Rockford, IL USA
Phone: (815) 397-2578 Fax: (815) 398-2578 www.rapidair.com
STOCK REELS CUTTERS STRAIGHTENERS SERVOS
