Page 23 - MetalForming September 2019
P. 23
the field and to improve our processes,” he says, explaining CI initiative goals and objectives. The metal shop pro- duces these brackets at very high vol- umes, running them for 1.5 shifts/day, 5 days/week. Hence the urgency, in 2017, to improve its stamping and welding efficiency. The solution: invest- ing in the application of a dry-film lubricant (DFL) to each master coil of steel at Chemcoaters in Gary, IN.
“We take in Fleet Engineers’ master coils and run them through our line,” says Ted Jarosz, new product and tech- nical service manager at Chemcoaters. technical sales manager at Chem- coaters. “The steel, 0.059 in. thick, is cleaned using two 30-ft. alkaline clean- ing processes and two hot-water rinses. Then the stock runs through a GFG roll-coating line, which applies the DFL (called Chemform), and then finally to an infrared oven for curing.”
Coated coils route to a service center for slitting, then Fleet Engineers runs the slit coils through a blanking line, and press operators feed blanks into the firm’s presses. “We negotiate our steel buy 6 to 9 months out,” Thorsby says, “and have our supplier release the master coils directly to Chemcoaters for slitting and for application of the DFL. It then ships us 10,000 to 12,000- lb. slit coils two to three times/week.”
The Cost Justification Equation
Chemform, an acrylic lubricant with a coefficient of friction of 0.04 to 0.10, says Jarosz, is designed to reduce or eliminate metal-to-metal contact and avoid galling wear. While the process does add about 10 percent to Fleet’s material cost, Thorsby says the benefits far outweigh the additional expense.
“We’ve seen a significant reduction in tool maintenance,” he says. “We’ve also eliminated the use of drawing compound, the need to stage operators at the presses to wipe excess oil from the stock, and post-weld spatter cleanup. In addition, we’ve significantly reduced the time required in our qual- ity department for weld inspection, and the associated costs from rejected parts and reworking.”
While the benefits have been great, Thorsby does note some adjustments made in the shop to accommodate the new DFL. “The lubricant is very slick,” he says. “To prevent the coils from tele- scoping, we’ve had to add extra strap- ping bands around the slit coils. And, rather than load blanks onto flat pallets for movement by forklift to the presses, we now stage the blanks on racks—to prevent the blank stacks from sliding off of the truck.”
Wait—There’s More
In addition to the DFL coating, Chemcoaters also offers a coating for- mulated and blended inhouse, called InterCoat ChemGuard, for use with galvanized substrate and incorporating metallic zinc. According to Jarosz, the coating has a coefficient of friction similar to that of wet lubricants during stamping. It also has a self-healing characteristic—once it becomes dam- aged, scratched or abraded in service it will still provide corrosion protection along the edges of a punched, sheared or cut edge.
When Jarosz presented the Chem- Guard process to Thorsby late in 2018, he immediately thought of the perfect application for another Fleet Engineers product: fabricated tire-carrier assem- blies, which are subjected to the harsh environment underneath each truck. Fleet Engineers also switched to the DFL for stamping these parts.
“Stamping these assemblies ben- efitted from switching to the DFL,” Thorsby says, “by minimizing tool wear and avoiding the need for press operators to sop up excess oil. Taking it one step further, Chemcoaters offers the ChemGuard coating with a few different tints (gray, black and blue) and the black fit right in with the tire carrier. We’re evaluating it with a gal- vanized sheet steel, replacing the HRPO material, and believe that the color-enhanced ChemGuard product will further enhance corrosion resist- ance and also eliminate the need for us to e-coat and powder-coat the assemblies. The savings may be sig- nificant.” MF
MetalForming/September 2019 21
