Page 82 - MetalForming October 2012
P. 82
   80
MetalForming/October 2012
Tooling Update
Tooling Technology
New Punch Options Provide Increased Flexibility in Profile Nibbling
 Thanks to new punch designs, the Tru- Tool PN 130 nibbler from Trumpf Inc., Farmington, CT, proves ideal for profile, corrugated and flat-sheet cutting often
found in roof and façade construction, plumbing and the heating and air-con- ditioning industry. A new standard feature of the profile nibbler is the HighSpeed
punch, which achieves quality cuts at a working speed of 10.5 ft./min. When the highest-quality cut is needed, the specially developed HighQuality punch supplies an extremely fine cut edge, produced at the slightly slower rate of 9 ft./min.
The ergonomic design of the electric nibbler, combined with a slim, light- weight and vibration-resistant structure, allows users to cut sheets as thick as 0.05 in., with optimum comfort and flex- ibility. The maneuverable tool is capable of cutting radii as small as 1 in., even in difficult to reach places.
A specially designed tool carrier pro- vides for fluid movement, and cutting direction can be adjusted 360 deg. for maximum flexibility. The quick tool- change feature permits the tool to be replaced in seconds.
Trumpf: 860/255-6000; www.us.trumpf.com
  Leading the Industry since 1965
Vast Industry Experience
Versatile Combination Systems
Single Powered Un-coiler
Coil Cars  Un-Coilers
Threading tables  Peeler / Threaders
Powered Straighteners
Electronic Servo Feeds  Cut to Length Systems
Space Saver Feed Systems  Complete Coil Feed Lines for most Materials including HSLA
Contact us for a complete quote
*Dealer inquiries Welcome
Colt Automation Ltd.2825 Argentia Rd, Mississauga, ON Canada. L5N 8G6 905-625-6600 www.coltauto.com
HD Space-Saver Feed System
   80   81   82   83   84
