Page 84 - MetalForming October 2012
P. 84
The Science of Forming
By Stuart Keeler
Advanced High Strength Steels Assist Stamping Weight Reduction
Tooling Technology
0.3
0.2
0.1
200 400 600 Engineering Yield Strength (MPa)
ble
Mild and HSLA Steel
Maximim Allowa n-Value
Minimum
Specified Yield Strength
Many industries are reduc- ing the weight of their stampings, especially automotive. In addition to weight reduction of the primary stamp- ing, secondary weight reductions occur in stampings that support the force or function of the pri- mary stamping. Reducing the weight of a vehicle body-in-white allows secondary weight reduc- tions in support axles, power transmissions and other areas of the vehicle.
A structural engineer directed
to reduce the weight of a load-
bearing stamping will learn from
his textbook that load capacity
equals material strength multi-
plied by the cross-sectional area
being loaded. Therefore, an
increase in strength can compensate for the desired reduc- tion in sheet thickness to provide a constant load-carrying capacity.
Unfortunately, the formability engineer now faces sever- al problems. For a specific type of steel, such as high-strength low-alloy (HSLA), an increase in strength reduces the work- hardening exponent (n-value—Fig. 1). In addition, specify- ing minimum yield strength establishes the maximum avail- able n-value. The n-value controls several key aspects of metalforming, including maximum allowable stretch and growth of localized strain gradients.
The onset of failure in sheetmetal stretching is a through- thickness or local neck that occurs just prior to fracture. The onset of this local neck terminates useful deformation throughout the stamping and is predicted by the forming- limit curve (FLC) for different combinations of surface
Stuart Keeler (Keeler Technologies LLC) is known worldwide for his discovery of forming limit diagrams, development of circle-grid analysis and implementa- tion of other press-shop analysis tools. Keeler’s metal- forming experience includes 24 years at National Steel Corporation and 12 years at The Budd Company Technical Center, enabling him to bring a very diverse background to this column and to the seminars he teaches for PMA.
P.O. Box 283 | Grosse Ile, MI 48138 Fax: 734/671-2271 keeltech@comcast.net
strains. These maximum allowable strains decrease as n-value and material thickness decrease. While weight reduction by increased yield stress and reduced thickness structurally compensate each other, capacity for stretchability and bendability suffer a double reduction.
In last month’s column we dis- cussed the importance of higher n- values in preventing or at least restraining the growth of severe localized strain gradients. Local- ized severe strain gradients mag- nify the variation from process input variables, causing increased swings in elastic stresses and changes in stamping dimensions. Weight-reduction programs that increase yield strength and reduce
sheetmetal thickness can generate these severe gradients. Fig. 2 summarizes the effects of lower n-values due to weight-reduction programs, with HSLA steel representing the low n-values and mild steel the high n-values.
Since the introduction of HSLA steels, metallurgists have succeeded in increasing their yield strength from ini- tial low values to the 110-ksi grades available today. How- ever, the reduction in n-value with increased strength fol- lows the same curve shown in Fig. 1. Microstructures of mild and HSLA steels are based on a ferritic phase. To break out of these metallurgical boundaries, advanced high strength steels (AHSS) were created using phases other than ferrite— martensite, bainite, retained austenite and austenite. Two
Fig. 1—The n-value decreases as yield strength increas- es. Specifying minimum yield strength limits the maxi- mum allowable n-value.
From Forming Limit Curve
High n Low n
From Circle Grids
Stamping Location
82 MetalForming/October 2012
Fig. 2—Reducing n-value lowers maximum stretchability (FLC) and increases peak gradient strain in the stamping.
Percent Stretch
n-Value
