Page 83 - MetalForming October 2012
P. 83
High-Force Manifold
System a Formability
Enabler
Hyson Products, Brecksville, OH, intro- duces the Nitro-Dyne 150-bar manifold system, promising to deliver consistent force for reliable part quality, and low pres- sure rise for improved part formability and increased press utilization. Three cylin- der sizes are available: the MOR 5200,
0.060 in., incorporating pin diameters from 0.062 to 0.188 in.
Hinge Tooling operation in the press is simple. Knuckles are formed from a pre-punched flat sheet containing the tabs for the forming operations. Two tools are used to make three hits:
• Hit one with Tool 1 produces the radius at the end of the knuckle.
• Hit two with Tool 1 produces the radius at the beginning of the knuckle. • Hit three with Tool 2 curls the form
to complete the knuckle.
Available in all tooling styles and sta-
tion sizes, Mate Hinge Tooling is made from high-speed tool steel
Mate Precision Tooling: 800/328-4492; www.mate.com
Tooling Update
Quick Die Change Success
HYDRAULIC Die Clamping
Hilma has been safely clamping dies for more than 50 years. We specialize in die change systems that maximize the output of your specific press. We stand behind our products, and provide you with the excellent service you need to remain competitive in today’s manufacturing environment.
www.clrh.com
Ellisville, MO 63021
(636) 386-8022 • Email: engr@clrh.com
Now Introducing MAGNETIC Quick Die Change
• Clamps existing dies without retooling
• Evenly distributed clamping force reduces tool wear
• Available for a range of sizes.
Hydraulic Die Change:
• Swing Clamps
• Sliding and Swing Sink Clamps • Wedge and Traveling Clamps
• Hollow Piston Cylinders
• Pumps, Control Panels
• Die Lifters
with a contact force of 52 kN; the 7700, with a contact force of 77.3 kN; and the 10700, with a contact force of 106.8 kN. Stroke lengths range from 100 to 250 mm.
Hyson Products: 440/526-5900; www.hysonproducts.com
Forming Hinges
in a Turret Press
Just Got Simpler
Mate Precision Tooling, Anoka, MN, now can form several different types, lengths and diameters of hinges for a vari- ety of applications using Mate Hinge Tool- ing. Use the tooling to form hinges from mild steel, aluminum and stainless steel in thicknesses ranging from 0.030 to
MetalForming/October 2012 81
