May 7, 2019Comments
As a specialist in automation processes, machining units, hand held power tools and abrasives, Suhner continues expanding its product range with special tools that can be mounted directly to the robot arm. A quick-change-tool system enables a variety of machining and finishing tools to be connected directly to a robot for continuous use.
Applications for these tools range from vehicle manufacturing to deburring operations, and from stainless-steel machining to drilling and tapping operations. The company provides a host of robot-tool solutions for surface-treatment and conditioning applications, with products for brushing, polishing, filing, belt sanding and more.
See also: Suhner Corporation
Technologies: Fabrication
There are no comments posted.New Abrasives Line Includes Flap Discs, Quick-Change Discs
Tuesday, May 7, 2019
Six-Axis, 100-kg.-Payload Robot Ideal for Many Applications
