Vacuum Suction Cups for Hot-Forming Applications
April 1, 2010Schmalz Inc., Raleigh, NC, introduces its HT2 vacuum suction cups designed for handling sheetmetal during the hot-forming process, to replace the use of mechanical grippers.
The firm also has expanded its series of vacuum ejectors with the SEAC-RP model, a decentralized vacuum ejector with an integrated air-saving function. Short gripping and blowoff times allow short cycle times in automated operations. And, the unit’s compact design and lightweight aluminum construction allow its use in robotic applications.
Schmalz Inc.: 919/713-0880; www.schmaltz.com
See also: Schmalz, Inc.
