Clamps Rated for Hot-Forming Applications
May 1, 2013Comments
PHD, Inc., Fort ne, IN, a manufacturer of industrial automation equipment, has introduced new high-temperature options for its Series GRM clamps, designed for use in hot-forming applications. The GRM clamps with the G11 option include replacement of urethane-based components with all metal components; high-temperature-resistant seals and lubricant rated to 392 deg. F; and ceramic-coated tips that minimize thermal transfer from the heat source to the clamp.
The new clamps are designed specifically for handling sheetmetal in stamping/fabricating press applications. The clamps are available in three sizes, 13 jaw styles and numerous jaw openings to fit a range of applications.
PHD, Inc.: 800/624-8511; www.phdinc.com/grm
See also: Phd, Inc.
Technologies: Stamping Presses, Tooling
There are no comments posted.Maximize Efficiency and Productivity of Aluminum Hot Stampin...
March 11, 2024 Webinar
AP&T Collaborating with ArcelorMittal for Press Hardening Ap...
Wednesday, April 17, 2024
