![](/assets/images/Fabtech-sm.png)
Electric, Vertical Toggle Clamp
June 26, 2023Comments
Carr Lane Mfg.
Booth B23090
Carr Lane Mfg. will debut its new Electric Vertical Toggle Clamp at FABTECH in Chicago. Metal formers can upgrade to the new clamp and experience unmatched control, durability and versatility. Whether you're operating equipment for CNC machining, metal working, welding, or any other application, the electric vertical toggle clamp is the perfect solution for your clamping needs.
Also demonstrated at FABTECH: the Carr Lane Clip Buddy, a high-capacity toggle clamp, and much more.
See also: ROEMHELD North America
Technologies: Pressroom Automation, Tooling, Welding and Joining
