Mate Expands Press Brake Tooling Line
January 8, 2025Comments
Mate Precision Technologies, Anoka, MN, has added more than 500 new items across its American Precision Style, Wila Trumpf Style and European Precision Style press brake tooling lines. The new additions include a complete selection of Amada fixed-height-style profiles, designed to reduce setup times and well-suited for bending operations with small production lots and a wide variety of projects. Having a consistent height for all punch profiles eliminates the need for multiple setups to account for uneven heights, and eliminates the need to make frequent adjustments to the safety beam—required when using standard tooling with uneven heights.
Mate also has expanded its range of punch and die profiles for its Wila Trumpf Style and patented American Precision Style with Maglock press brake tooling. Using rotating supports to bend up to 40 deg. without marking, the Wila Trumpf Style version of CleanBend now is available in eight sizes. Variable openings range from 8 to 78 mm, with one option that includes an adjustable, variable opening between 40 and 100 mm.
New accessories added to the line include heavy-duty radius holders and radius inserts, as well as punch adapters and extenders.
See also: Mate Precision Technologies
Technologies: Bending
