Deburring Small Tube and Pipe—the Right Tool for the Job
March 14, 2016Comments
Pferd Inc., Milwaukee, WI, introduces Polistar-Tube flexible abrasive stars, designed to deburr hard-to-reach inner surfaces of tubes, bores and pipes from ¼- to 1.5-in. dia. To prevent corrosion on stainless-steel pipes, the abrasive stars are manufactured using stainless-steel rivets. Use them to clean and fine-grind bores; remove heat discoloration in stainless steel after welding; radius bore inlets and outlets; and deburr in cross bores. Users can stack the stars in several layers, aligned at an offset from one another, to optimize their efficiency.
http://www.pferdusa.com/Technologies: Bending
There are no comments posted. Bending
Creative Approaches to Common Press Brake Challenges, Part 1...
Tuesday, January 2, 2024
Tuesday, October 31, 2023
