Schwarze-Robitec Delivers Second Tube- and Pipe-Bending Machine to Framo
July 12, 2021Comments
After successfully using a heavy-duty model CNC 220 HD tube-
and pipe-bending machine from Schwarze-Robitec for a few years, Norwegian metal
fabricator Framo has purchased a second machine. Like its sister machine, the newest single-stack
CNC 80 HD at Framo is designed for continuous use under heavy loads. It bends
tubes and pipes up to 89-mm dia. with a maximum wall thickness of 7.6 mm. In
addition to smooth stainless-steel pipes, even high-strength duplex steel with can
be processed. Both the CNC 220 HD and the CNC 80 HD have an integrated flange-pipe
device that eliminates the need for subsequent flanging of pipes.
Industry-Related Terms: CNC (Computer Numerical Control), Model, Thickness
See also: Schwarze-Robitec GmbH
Technologies: Bending
