Planisher Flattens Coil-End Welds to Allow Continuous Metalforming
May 1, 2009Comments Kent Corp., North Royalton, OH, has developed a new coil-end weld planisher, which has a fixed upper planisher roll that is hydraulically driven on two linear bearings. The lower anvil adjusts up and down via a precision screw-and-wedge assembly, and a machine-mounted dial indicator allows the anvil to be positioned to precisely match material thickness. This prevents over-planishing and eliminates the need to adjust pressure for each sheetmetal thickness. The planisher will flatten gas-tungsten-arc welds back to original sheetmetal thickness to allow the welds to easily pass through rollform, tube and progressive-die lines. This also allows for strip processors to sell the weld in their final product.
Kent Corp.: 440/237-9286; www.continuouscoil.com
See also: Kent Corporation
Coil and Sheet HandlingElectric Dodge Charger Production at Stellantis-Windsor Plan...
Tuesday, December 17, 2024
Video Coil and Sheet Handling
Thursday, October 17, 2024
Dallas Industries Delivers Feed Line to Precision Tool & Sta...
24-In.-Wide Press-Feed Line on Display
Thursday, July 25, 2024
Canadian Stamper Orders Automatic Feed CTL Line
Monday, January 9, 2023
