High-Efficiency Onsite Nitrogen Generator
December 13, 2024Comments
South-Tek Systems has launched the N2Gen-Flex nitrogen generator for operations seeking to generate and use nitrogen onsite. The generator uses Pressure Swing Absorption (PSA) technology to deliver the most efficient air-to-nitrogen ratio in the industry, according to company officials, who explain that PSA reduces energy consumption by 20% or more when compared to traditional nitrogen generators, ensuring lower operational costs and a longer lifespan for the system's components. It is engineered to provide high performance, flexibility and cost-effectiveness for operations requiring nitrogen in 95-99.999% purity, and flow rates from 400 to more than 2200 cu. ft./hr.
“The N2Gen-Flex’s low air requirement and minimal pressure drop allows users to pair it with a smaller compressor than the standard PSA nitrogen generator, saving money in upfront cost, electrical demand and system maintenance,” says Garrett Rinker, Ph.D., South-Tek Systems mechanical engineer. “As a result, it provides a longer-lasting, more reliable solution that saves businesses both time and money—with full control of their operations at a predictable cost, without dependence on nitrogen delivery and supply-chain volatility.”
See also: South-Tek Systems
Technologies: Cutting
