What proved so persuasive in those bullet points? Here’s an example: One PowerPoint slide on part-nesting capability showed a nest of 187 parts on a first-attempt ProNest-programmed sheets as compared to 178 parts via the previous software, resulting in saving one full sheet ($320) on a job. And, ProNest required 1 min. of programming for this job as compared to 30 min. for the old software. Another: For estimating, with the feed rates, workcenter rates and material costs integrated into ProNest, the software creates 99-percent-accurate laser-operation prices. And, estimators can use PDF and DXF files to create quotes, with the software’s AutoNest module enabling one-click identification of the optimal sheet size in inventory for that particular part, and creating an accurate quote in about 1 min. depending on part complexity.
Hypertherm-Parts-List-Highlights-ProNestToday, with ProNest in place and running on laser cutting machines across multiple locations, Toop and laser cutting operators, programmers and estimators make use of various software features to save money and time, including these key modules:
  • Automatic Nesting enables one-click nesting. Users can choose their preferred nesting strategy to control the balance between nesting speed and material utilization, or select IntelliChoice for the software to determine an algorithm-based strategy.
  • Nesting System Optimization determines the ideal sheet size for a  particular set of parts. The module reportedly calculates every possible combination of parts, plates, remnants and different nesting strategies until it finds the best possible outcome.
  • Common Line Cutting enables sharing of the common edges of adjacent parts. This feature can be applied automatically to similar parts or manually for dissimilar part profiles, with kerf compensation automatically applied. Using this feature results in fewer pierces and reduced cutting distance to maximize productivity and consumable life while saving material.
Huge Reduction in Programming Time
Besides the benefits brought by the nesting software to Standard Iron & Wire Works identified above by Toop, he has another.
New Updates to Nesting Software
Hypertherm Associates Software Group recently released a major update to its ProNest 2023 software, including  enhancements to its Production Manager, a web-based module that reportedly integrates seamlessly with Hypertherm’s Edge Connect CNC to automatically capture real-time machine data. Enhancements include the ability to edit production times for completed nests, set job status changes, and search for nests by customer. Another feature merges XPR setups. The software now automatically detects and merges changes made to the process parameters or bevel spreadsheets into a new setup during installation. Users can choose to use their existing customizations or the latest factory cut charts.
User-interface upgrades include a new welcome screen and customizable ribbon. The welcome screen contains an informative dashboard that highlights training videos, application tips, and other valuable resources while the ribbon allows users to add, remove and rearrange tabs. Users can save different ribbon configurations and switch between them as needed to best fit their workflow.
“We have what we call T jobs—internal jobs such as parts for fixtures and check gauges,” Toop says. “Suppose a fixture requires 10 separate parts. With our prior nesting software, we would tab all of those parts (separate CAD files) together and bring them into the nesting software as a single part, a couple-hour process. Now with ProNest and its tabbing capabilities, we can nest a T job in 5 min. That time savings is important for us. With this and other nesting-software capabilities, our programmers nest only 2 to 3 hr./day, whereas when I started they were nesting 10 hr./day.”
The difficulty in finding qualified employees first influenced Standard Iron & Wire Works to bring in the new nesting software.
“Trying to replace people who’ve programmed for 20 years or more as they retire is becoming more and more difficult,” offers Toop. “Since we brought in ProNest, we’ve put together work instructions for nesting. Combined with the software’s ease of use, we have put people who have never nested on a computer, given them the work instructions, and said, ‘Nest these work orders.’ They can do it!”
Ease of use helps, too, with filling in across the manufacturer’s various locations when a programmer is out sick or on vacation.
“Just recently,” Toop says, “we had programmers in two locations who were out. I was able to sit here and nest for all of these plant locations. With the old nesting software, we didn’t have the ability to program efficiently across locations.”
Significant Boost in Material Utilization
With ProNest in place, Standard Iron & Wire Works has set about consolidating its sheet sizes. “With this nesting software, we have such improved utilization that we almost never want to use a smaller sheet,” Toop says. “Pro-Nest does such an excellent job with dynamic nesting that we try to use bigger sheets, which cuts down on table changes. We’ve been eliminating smaller sheets where we can, except on our turret punch presses, which have smaller tables that require the smaller sheets.
“We’ve seen huge material savings since bringing in the new nesting software,” he continues. “It allows for tighter nesting due to the solid algorithms as well as features such as collision detection and avoidance, and common-line cutting. And, we're pumping out a lot more product now just because we we're saving on table changes. We're placing so many more parts on a sheet that even with our automation—cranes and automated stack loading—we're having to bring extra people to unload the sheets. We’re cutting so much more so quickly now.”
Customization Pays Dividends
Sheet-size consolidation is one of a few initiatives undertaken by the manufacturer resulting from the new nesting software.
For example, the ability to customize ProNest led to additional projects courtesy of Standard Iron & Wire Works’ IT team, led by Dan Welter. This includes classification of parts to better track what’s needed and when.
“Due to an uncontrolled process, we had been cutting more parts than needed, destined for press brakes,” Toop recalls. “We would add parts to a sheet because we had room on that sheet, and ended up throwing them away because we already had too many of those parts. Now, thanks to Dan’s work, we developed part classes based on their value and demand. We can check to see what parts are needed, and their value, and then determine if we want to cut more of those parts to fill a sheet. Now we only run extra parts as they’re needed, because we know what we have on hand. For example, if we know that a part is a service part, we only need 10 of those. No need to run extra because they have nowhere to go.”
Other custom software additions include the ability to filter for specific material at specific plant locations and filter for expected feed rates for jobs, as well as generate customized reports. And, ProNest allows the ability to better save jobs and reports, as the old software only saved to a set amount and after that would begin overwriting, according to Toop.
“ProNest really opened the door to some of our skeletons, or issues that we should address to save time and/or money, and increase productivity,” Toop says. “We didn't realize that by purchasing new nesting software that we would open up so many doors, but we did.” MF
Industry-Related Terms: Bending, CAD, CNC, DXF, Edge, Fixture, Forming, LASER, Material Utilization, Nesting, Plate, Point, Run, Turret
See also: Hypertherm, Inc.
Technologies: Cutting, Software
