Band-Saw-Blade Solutions
October 1, 2018L.S. Starrett Co., will show its latest band-saw-blade solutions, including Versatix MP bi-metal blades with triple-tempered, high-speed M-42 cobalt steel teeth. The tooth design dissipates stress during cutting, reducing tooth breakage and increasing blade life. Stronger, longer-lasting blades are made possible, says the company, because of the Bi-Metal Unique technology. Instead of a single wire welded to the outside of a steel backer, this process bonds two strips of high-speed steel to each side of the top edge of the steel backer, using intense heat and pressure. The bonding area between the backer and the high-speed steel is increased 170 percent over conventional electron beam or laser welding processes.
Also being shown, a new web-based PowerCalc program to determine the correct saw, operating speeds, and power tool or machine for the application at hand.
See also: L.S. Starrett Company
Technologies: Fabrication
New Abrasives Line Includes Flap Discs, Quick-Change Discs
Tuesday, May 7, 2019
