Hydraulic Plate Rolls and Other Bending Equipment
October 1, 2018Comments
Carell will unveil its new line of Parmigiani VBH four-roll, double-pinch, hydraulic plate rolls (pictured) featuring the new Stradivari CNC 3D CAD graphic controls as well as Field-Bus and Facile systems technology. These machines include touchscreen controls, digital roll balancing, variable speed movements and time-saving onboard diagnostics, as well as FFD monoblock main frame designs.
The company also will exhibit its ETM-90 3-in.-capacity rotary pipe and tube bender with new touchscreen auto-calculating digital controls, and solid-steel frame that contains no castings. Also displayed: 3- and 4-in. CNC angle rolls with radius interpolation; 40-ton Digi-T40 horizontal press with SIMplylogik NC dual-axis controls; and hydraulic pyramid section benders in 1.5- and 2-in. capacities with digital controls.
See also: Carell Corporation
Technologies: Fabrication
There are no comments posted.New Abrasives Line Includes Flap Discs, Quick-Change Discs
Tuesday, May 7, 2019
FabricationNew Rapid-Delivery Program for Lifting and Positioning Equip...
FabricationRobot Tools for Drilling, Finishing and More
