Large-Angle 18-V Grinder
May 15, 2018Comments
Milwaukee Tool has introduced the M18 Fuel, featuring a 9-in. grinding capacity and billed as the world’s first 18-V large-angle grinder. The 7-in./9-in. model generates the power of a 15-amp corded large-angle grinder, and reportedly is as much as 2 lb. lighter than the leading corded unit.
Watch the Video
The new grinder combines three Milwaukee innovations: the PowerState brushless motor, which delivers speed and capacity to grind and cut through difficult applications without slowing down; the RedLithium High Output HD12.0 battery that provides 50 percent more power, runs 50 percent cooler and delivers 33 percent more run time than the M18 RedLihtium HD9.0 battery; and RedLink Plus intelligence to ensure maximum performance of the tool under load and prevents against overload and overheat.
This grinder is compatible with Milwaukee Tool’s entire M18 line of more than 150 power-tool products.
Milwaukee Tool: www.milwaukeetool.com
See also: Milwaukee Tool
Technologies: Fabrication
There are no comments posted.New Abrasives Line Includes Flap Discs, Quick-Change Discs
Tuesday, May 7, 2019
