Electronic Control, PLC Integration for Lubrication Systems
May 21, 2019Comments
Amcol Corp. has introduced electronic control and PLC integration to its 6000-series precision lubrication systems for Minimum Quantity Lubrication (MQL). Amcol’s MQL incorporates accurate spray equipment to send minute amounts of concentrated lubricants to the cutting tool/workpiece interface, maximizing tool life and providing a near dry environment. Applications include forming, stamping, piercing, sawing and machining.
By adding electronic control, the 6000 series can be programmed through a PLC to provide a high level of control over the amount and timing of lubricant application, permitting more precise application. The injector used in the 6000 series can dispense liquid in as little as 20 msec., a nearly instantaneous reaction time that can keep up with rapid and demanding cycle rates. PLC control enables application only when and where needed.
PLC control also allows recipe programming for flexible, short-run manufacturing. The technology can be programmed for different tooling, operational speed, part size and alloys in the same machine. That means no more setting and resetting for different parts, or using one generic lubricant setting for all tools and parts, according to company officials, which helps reduce setup times, lubricant consumption and residue.
See also: Amcol Corporation
Technologies: Lubrication, Sensing/Electronics/IOT
There are no comments posted.Revolutionizing Automotive Manufacturing with 5G and AI
Monday, March 18, 2024 Video
10 Questions: How to Determine Which Type of Control to Outf...
Patrick Thomas Monday, February 26, 2024
Guide for Using Digital Work Instructions
Wednesday, January 24, 2024
Five Factors in Selecting a Resolver-Based Die-Protection Co...
Jim Finnerty Friday, January 19, 2024
