FloodStream Liquid Nozzle for Spray Applications in Tight Spaces
May 28, 2024Comments
For spraying processes where space is at a premium, Exair
introduces the new 1/8 NPT FloodStream liquid atomizing spray nozzle. Producing
a deflected flat-fan pattern, the FloodStream provides a consistent and
proficient spray for precise coverage in close quarters. Manufactured from Type
303 stainless steel, common applications include washing/wetting, dust
suppression, lubrication and part cooling.
Like all Exair spray nozzles, the FloodStream is versatile and efficient. With a maximum operating pressure 250 PSI, the nozzle channels liquids through the body and against a precision-tuned, angled surface. This creates a wide-angle, flat-fan spray pattern at 75 deg. from nozzle orientation. The nozzle’s compact build optimizes its effectiveness in tight spaces while still providing exceptional, precise coverage. The stainless-steel construction also provides durability and corrosion resistance, and works well with water, light oils, rust inhibitors, chemicals, paints, dyes and other common liquids.
See also: Exair Corp
Technologies: Lubrication
