Fluids and Reduction Systems
July 27, 2023Comments
Impact Fluids
Booth D41056
Visit Impact Fluids at FABTECH to learn how the firm helps metal formers reduce their environmental impact and improve their bottom line through proper fluid selection and mixing, and selection of the optimum application equipment. It uses a proprietary fluid lifecycle-analysis process to review each step the fluid takes in its flow through a facility to identify areas of waste and inefficiency. It then recommends systems and fluid alternatives to mitigate waste; the savings realized typically are 50 to 75 percent of fluid usage and related costs.
See also: Impact Fluids, Inc.
Technologies: Lubrication
