Chicago Architectural Upgrade Features 1960 sq. ft. of Bar Grating
April 7, 2020Comments
Direct Metals, a steel service center with locations in Kennesaw, GA, and Waukegan, IL, has provided 1960 sq. ft. of bar grating handrail inserts for the recently completed renovation of the Citadel Center in Chicago, IL. The bar grating, installed on the center’s new rooftop deck, is a special manufactured press lock material custom cut and designed by Direct Metals to give an aesthetic flair to the flagship building.
Direct Metals carries inventories of perforated metal, bar grating, expanded metal, safety grating, fiberglass grating, architectural metals, handrail components and wire mesh products, available in carbon steel, stainless steel, aluminum, copper, brass, bronze, fiberglass or galvanized metal. It performs several fabricating processes including cutting, shearing, sawing, punching, welding, slitting and blanking; www.directmetals.com.
See also: Direct Metals Co LLC
Technologies: Materials
