Air-Distribution Manifold Assemblies for Stamping Applications
June 13, 2023Comments
Ross Controls
Booth D40927
Ross air-distribution manifolds provide individual control
of machinery with multiple pneumatic circuits. Mechanical presses may have
clutch/brake, counterbalance, mechanical-device, automation-device or die-cushion
circuits. Air-distribution manifolds allow centralized locations, independent
pressure control and independent lockout capability for each pneumatic circuit.
Ross air-distribution manifolds are available in 0.75- or 1.25-inlet-port sizes and in two- or three-station assemblies. Individual manifold blocks of any size or configuration can be connected to make larger manifold assemblies to meet virtually any machine application. Each station circuit can be customer-specified to include pressure-regulation, check-valve or lockout-valve functions.
Gauges are provided for regulator setting as well as for confirmation of downstream energy removal when the lockout option is selected. Large 0.75- or 1-in. auxiliary ports are available on each station for unregulated main air connections (air tools or other devices). Small 0.25-in. auxiliary ports are available on each station for external pilot lines or test-port requirements. Maintenance and service are simplified with top-loaded regulators, cartridge check valves and base-mounted lockout valves, eliminating the need for removing manifolds or assemblies for service.
See also: Ross Controls
Wintriss Expands Tennessee Sales and Service Representation ...
September 26, 2024
Picking Press Controls for a New Press or Retrofit
Todd Wenzel Friday, March 7, 2025
Delta Motion Adds EtherCAT MainDevice Capability to its RMC2...
Friday, February 21, 2025
Yaskawa America, Inc. Names New Leader for Drives Group
Monday, November 18, 2024
