Press Control Easy to Use, Simple to Install
October 1, 2010Comments
ISB, Lachine, Quebec, Canada, will exhibit its compact press and mechanical press brake resolver-based control system. Easy to use and simple to install, the control includes eight die-protection inputs, PLS outputs, multiple timers and numerous operating modes, all from a simple keypad. Networking—for tracking production—is an option that does not require special software.
Also on display: Merlin 3000 programmable light curtains for guarding press brakes; standard light curtains for presses and other hazardous industrial equipment; Softouch buttons designed to replace existing mechanical buttons; GPA dual safety valves for clutch and brake units; and Fabmat floor mats.
See also: ISB
