Shrinkwrap Protects Metal Products from Corrosion
October 1, 2008
To protect costly metal parts and products against weather damage, turn to Dr. Shrink’s (Manistee, MI) premium shrinkwrap, which protects products from moisture and corrosion.
Shrinkwrap
Able to cover almost all objects and machinery, the shrinkwrap stays in place and won’t scratch or chafe the covered pieces. Constructed from 100 percent virgin resin, Dr. Shrink’s shrinkwrap contains maximum UV inhibitors for long-term protection. Covers can be ventilated to help prevent mold and mildew. Volatile corrosion inhibitors also are available to keep moisture and corrosion from forming. Zipper access doors provide simple entry for maintenance without cutting or removing the shrinkwrap.
Durable the wrap comes in widths of 12 to 40 ft. and thicknesses of 6 to 12 mils. Dr. Shrink also offers specialized tapes for attaching the shrinkwrap, and the green Rebag recycling program.
Dr. Shrink: 800/968-5147; drshrink@dr-shrink.com
Industry-Related Terms: Forming
See also: Dr. Shrink Inc.
