Nano-Ceramic Grease Ideal for Forklifts and Lift Trucks
June 1, 2012Comments
Dayton Progress, Dayton, OH, has introduced DayLube high-performance grease, recommended for the protection of forklift and lift-truck masts and runners conveyor bearings, bushings cables, cams, chains, gears, lifters, machine parts, robotics, slides, wear plates and the like. The grease features nanoceramic particles that act as sub-microscopic ball bearings to provide continuous lubrication to steel surfaces. With a lower coefficient of friction at all temperatures than traditional PTFE greases, chemically inert DayLube also is environmentally friendly.
The lube maintains its viscosity across a temperature range of -40 to 800 F, and boasts extraordinary adhesion to extend production by as much as 10-times compared to other greases. It has high load-bearing properties, a low dielectric constant, does not contain metal or silicone and resists steam, acids and most chemical products.
DayLube comes in 16-oz. tubes and in cases of 12 each.
Dayton Progress: 937/859-5111; www.daytonprogress.com
See also: DAYTON Lamina Corporation
There are no comments posted.Catalog: Pneumatic-Thruster and Rodless Linear Slides
Tuesday, October 1, 2024
Motion Industries Names Esposito Group VP for Motion Automat...
Tuesday, January 2, 2024
Conveyors—Four Steps for Maximizing Performance and Minimizi...
Mike Hook Thursday, July 27, 2023
Metal Forming Strategies for Overcoming Economic Crises
Stephan Robertson Tuesday, May 19, 2020
