High-Speed Ethernet Module Enhances Robotic Tool-Changer Performance
September 27, 2024Comments
ATI Industrial Automation (ATI), Apex, NC, has introduced
its GBX 10 Gigabit Tool Changer Ethernet Module, designed to provide reliable
transmission of high-speed data, signals and fieldbus communication for
advanced automation, AI and Industry 4.0 robotic systems. Features:
- Plug-and-play M12 8-pin X-code connectors for safe and reliable pass-through of Cat6/Cat6a industrial Ethernet cables, saving time during integration, with no stripping, crimping or soldering required.
- Configurable cable-exit options between -90, 0 and +90-deg. radial positions, allowing users to optimize cable dress and routing to reduce cable strain and maximize system uptime.
- Longevity, handling up to one million mating cycles to support applications in advanced industries such as automotive and aerospace.
- Broad compatibility with ATI standard and heavy-duty tool changers, and utility couplers for widespread module standardization.
See also: ATI Industrial Automation
There are no comments posted. Sensing/Electronics/IOT
August 5, 2024
Work-Instruction Software Enables Workers to Activate, Monit...
August 5, 2024
Exair Partnering with University of Cincinnati Robotics Team...
Monday, May 12, 2025
