Ultrasonic Leak Detector for Compressed-Air Systems
June 29, 2023Comments
Exair has debuted a new ultrasonic leak detector (ULD), a
hand-held instrument engineered to help locate the source of costly leaks in
compressed-air systems. Use the ULD, upgraded in look and function, to identify
and pinpoint costly leaks, allow quick repair and enjoy subsequent cost
savings. Testing the various unions, pipes, valves and fittings of a complete
installation can be done quickly and effectively at distances to 20 ft. away.
If such a leak exists, high-pressure gas creates high-frequency turbulence when moving into an area with lower pressure, creating an ultrasonic or “white-noise” sound beyond the range of human hearing. The ULD detects these vibrations and generates an audible sound through supplied headphones, and also indicates intensity via a front-facing LED display. The ULD can be adjusted to filter out background noise in busier plants, with buttons to fine-tune sensitivity.
This new model offers a heightened ability to detect leaks in hard-to-reach areas while also complying with the IEC 61326-1 standard that designates its ability to operate in the electromagnetic environments typically found in industrial plants.
See also: Exair Corp
Technologies: Quality Control
There are no comments posted.Portable Wide-Area CMM
Tuesday, July 8, 2025
CMM Boasts Digital Integration, and Delivers Speed, Precisio...
Tuesday, May 6, 2025
Faro Debuts Handheld Scanner, Updates Software
Friday, February 21, 2025
Updated 3D-Measurement Software Offers Modules to Handle Var...
Wednesday, February 5, 2025
