Hydraulic Benchtop Presses
July 21, 2021Comments
Multipress
Booth D46651
Hydraulic press manufacturer Multipress will showcase its model M5P and W6A benchtop presses, both with dual anti-tiedown start buttons, pressure-shift speed change and pressure reversal, and the ability to run with an optional rotary index table or other material-handling devices. All adjustments, pressures and stroke positions can be modified from the operator’s position at the front of the press, and pressure regeneration allows for fast approach until the workpiece is contacted.
Benchtop models range from 1 to 20 tons, with larger models available to 1200 tons. Representatives will be available to discuss the company’s full line of C-frame and four-post presses, as well as customized press solutions for a variety of applications.
See also: Multipress, Inc.
