Compact Resistance-Welding Workstations
January 29, 2024Comments
Amada Weld Tech, Inc., a manufacturer of welding, marking,
cutting, sealing and bonding technology, announces the WR series of resistance-welding
workstations. The workstations combine a power supply, transformer, weld head,
process monitor and workbench into a compact workstation designed to simplify
operator welding tasks while maximizing quality and reliability.
They are suitable for applications such as making copper electrical connections, hot crimping, welding and sealing radio-frequency and hybrid devices, and automotive component assembly.
The WR series uses closed-loop DC inverter technology to 60,000 A. A cascade feature enables the use of one power supply for several workstations. The workstations can be integrated with either Amada Weld Tech MH-1501 or KN-200A weld heads.
The monitor captures weld data for real-time comparisons to a known good reference, providing an alert when conditions fall outside of defined weld limits. In addition, the data can be used for advanced analysis in statistical process control programs or overall equipment efficiency programs.
Safety features include anti-tie-down buttons to safely initiate the weld cycle and shielding to protect the operator during production.
See also: Amada Weld Tech Inc
