New Vertical Mill Commissioned at Weld Systems Integrators
April 14, 2023
weld-systems-integrators-haas-millWeld Systems Integrators (WSI), Warrensville Heights, OH, has installed and commissioned a new Haas TM-2P vertical toolroom mill, to further enhance its machining and production capabilities. The taper mill, which features a 10-pocket automatic tool changer and 40 by 20 by 16-in. work area, joins a CNC lathe and four Bridgeport mills in the firm’s machining and production center and will be used to produce standard and custom parts for WSI ‘s line of resistance welding machines and related equipment.
Industry-Related Terms: Center, CNC
See also: Weld Systems Integrators, Inc.
Technologies: Tooling, Welding and Joining
