HFA Extruders Quickly Deliver High-Quality 3D Prints
June 1, 2017Comments
3D Platform (3DP), Rockford, IL, a manufacturer of large-format, industrial-strength 3D machines, has produced a high-flow air-cooled (HFA) filament extruder that features a gear-reduction transmission to prevent filament stripping and slipping, and print-layer resolution to 50 microns. The extruder comes with the company’s 3DP 300 Series WorkbenchPro printer, and as an available upgrade option with the 100 Series WorkTable and 200 Series WorkbenchClassic.
“Our new line of quick-swap dual extruder heads deliver high-quality 3D prints and are independently controlled for speed and extruded material amounts,” says company president Jonathan Schroeder. “The heads can accommodate filament sizes from 1.75 to 3 mm and nozzle sizes from 0.2 to 2.5 mm.”
3D Platform: www.3dplatform.com
See also: 3D Platform
Technologies: Additive Manufacturing
Additive ManufacturingMeltio and Phillips Collaborate on Hybrid CNC Machining and ...
Monday, June 9, 2025
AM for Tooling: Making Headway
Lou Kren Monday, March 3, 2025
Additive ManufacturingAM Event, RAPID + TCT 2025, Slated for Detroit in April
Friday, February 21, 2025
