Certifications
April 1, 2010Comments
Harco Metal Products, Tempe, AZ, received ISO 9001 certification. The firm fabricates tubular components and assemblies.
Manchester Tool & Die, North Manchester, IN, a supplier of tube end-forming equipment and tooling, received ISO 9001:2008 registration. Its products fabricate tube from 3⁄16- to 3-in. OD for fluid, gas and heat-transfer equipment.
Metalforming company A.J. Rose Mfg., Cleveland, OH, has been granted a Commercial and Government Entity (CAGE) code by the Defense Logistics Information Service. The code is a unique identifier assigned to suppliers to various government or defense agencies. Although originated by the Department of Defense (DoD), CAGE codes also are used by the Department of Transportation and NASA, and other federal government agencies. A.J. Rose offers transfer-press capacity to 1000 tons, progressive-die press capacity to 600 tons, and also performs spinning, CNC machining, welding, grinding and other processes.
The Innovative Fluid Handling Group, Rock Falls, IL, has been registered to the ISO 9001:2008 quality-management system. The company manufactures custom fuel tanks and hydraulic reservoirs, and lubricant-storage and dispensing systems. Its equipment list includes high-power laser-cutting machines and robotic arc-welding cells.
See also: A.J. Rose Manufacturing Co., IFH Group, Manchester Tool & Die Inc, Harco Metal Products Inc
Technologies: Bending, Lubrication, Quality Control
Dan T. TUE, MAR 17, 2020 @ 12:51 AM
Hello World
Seeking Small Victories: Continuous Process Improvement
Daniel Schaeffler September 25, 2023
Use Lean Six Sigma for Efficiency & Quality Improvement
Daniel Schaeffler Friday, October 27, 2023
In-Process Inspection Software Provides Real-Time Visibility
Tuesday, March 28, 2023
