Gear Couplings for a Host of Fabrication Applications
October 1, 2014Comments
Desch Canada
Booth B1413
Desch gear couplings are flexible-shaft connections suitable for a positive-torque transmission. They’re designed to compensate for radial, axial and angular shaft misalignments. The gear couplings are made of steel with grease lubrication and O-ring seals.
Desch gear couplings are used in all areas of mechanical engineering and offer a long service life with maximum reliability, resulting from the optimal grease lubrication of the crowned spline. The couplings are generally suitable for horizontal assembly; special types are suitable for vertical assembly. Use them for shaft diameters from 20 to 1000 mm. www.desch.de/en
See also: DESCH Canada Ltd.
Technologies: CNC Punching, Coil and Sheet Handling
There are no comments posted.Scotchman Introduces FI 125-Ton Integrated Ironworker
Monday, May 12, 2025
Scotchman Industries Names Kent Bradley Director of Marketin...
Tuesday, February 25, 2025
