Fab.-Tooling Solutions
June 12, 2023
Wilson Tool International
Booths A2913, D40816
Wilson-Tool-EXP-punch-tips-FABTECH-2023Visit the Wilson Tool International booths to consult with technicians on tooling needs and to learn more about EXP punches (pictured) that reduce the number of times that tools must be pulled out of the machine and sharpened due to the long-lasting quick-change tips. Also on display: press brake clamping systems for upper and lower beams that can be added to virtually any press brake, new or old, to speed tool changeovers and reduce downtime. The company also showcases custom press brake tooling to simplify complex bends.
And, HP Accu-Lock special retainer inserts enable needed retainers to be made inhouse, thus eliminating the need for complicated jigs, inspection fixtures and specialized knowledge to machine ball holes into the punch plate.
See also: Wilson Tool International
Technologies: Bending, CNC Punching
