Alabama Welcomes New Steel-Coil Processing Plant
May 1, 2009Comments
Friedman Industries, Inc., Houston, TX, has opened a new coil-processing plant in Decatur, AL, to convert hot-rolled coils received from the adjacent Nucor Steel Co. mill into hot-rolled sheet and plate. The new 48,000-sq.-ft. plant houses temper-passing and leveling equipment to provide consistently flat material and tight tolerances. Friedman also operates a coil-processing plant in Hickman, AR, and a tubular-products facility in Lone Star, TX.
Friedman Industries, Inc.: 800/527-8671; www.friedmanindustries.com
See also: Friedman Industries
There are no comments posted. Coil and Sheet Handling
Monday, January 9, 2023
Canadian Stamper Orders Automatic Feed CTL Line
Tuesday, November 9, 2021
Automation-Ready Below-the-Hook Grab for Steel, Aluminum Coi...
Wednesday, July 21, 2021
New-Look Exair Website Features Improved Search Function
