Coil-Feeding Products
March 1, 2008Comments
Littell International, Inc., Schaumburg, IL, showcases the Littell No. 225 feed with pull-through straightener. Designed to run material to 0.100 in. thick, this compact package is ideal for manufacturers with production space limitations. Its space saver combination is available for quick delivery, and the package also is available on larger Littell feed models.
The company offers a range of coil-feeding products, in widths from 6 to 72 in., and will display literature and photos of this equipment.
www.littell.com
See also: Littell, LLC
Andritz to Supply Cut-to-Length Line to Olympic Steel in Min...
February 11, 2025
