Folding Machine Boasts One-Click Programming
October 1, 2016Comments
RAS Systems, LLC, will show its new XLTbend 11-gauge mild-steel (13 gauge on 4-m model) folding machine. With one-click programming, the Bendex3D-powered XLTbend can import DXF, STP and GEO files directly into the control. Add to this a hybrid backgauge solution that allows the operator to place the workpiece, and the machine takes over from there.
The XLTbend folds up and down and can be operated from the front or rear.
www.ras-systems.com
See also: RAS Systems, LLC
Technologies: Coil and Sheet Handling, Fabrication
Andritz to Supply Cut-to-Length Line to Olympic Steel in Min...
February 11, 2025
Press Feed Strong
Kate Bachman Wednesday, April 23, 2025
5 Questions About Air Feeds; 5 About Servo Feeds
Bradley Nordlof Thursday, April 17, 2025
