Stainless Supplier Fires Up New CTL Line
March 1, 2011
Penn Stainless Products, Quakertown, PA,
Stainless Steel fires up new CTL Line
a supplier of stainless-steel sheet, plate, bar, structural, pipe and tubular products, has installed a heavy-gauge cut-to-length line from Herr-Voss Stamco. The line, which includes a precision leveler (with 4-in.-dia. work rolls), overhung mandrel-type uncoiler, three-roll breaker and entry-crop shear, will allow the firm to expand its leveling capabilities on surface-critical 2B sheet finish, and corrective leveling on 0.375-in. material, according to Penn Stainless president Jim Seward. Line capacity: 50,000-lb. coil weight, 78-in. wide, material thickness 0.090 to 0.375 in.
Besides precision leveling, Penn Stainless offers plate and sheet shearing, plasma and waterjet cutting, and machine and saw cutting.
Penn Stainless: 215/536-3053; www.pennstainless.com
Herr-Voss Stamco: 800/380-3180; www.herr-voss.com
Industry-Related Terms: Plate, Shearing, Thickness
See also: Herr-Voss Stamco, Penn Stainless Products
Technologies: Coil and Sheet Handling, Materials
