Visionary Manufacturing Solutions Opens in Rochester, MI
May 14, 2020Comments Rochester, MI, welcomes a new metal forming machinery dealer and distributor: Visionary Manufacturing Solutions (VMS), established by J. Hunter Coe, formerly the CEO at Coe Press Equipment. VMS, which will serve the metal forming industry in Michigan and Canada, represents companies providing technology in the following areas: press automation, coil processing, cut-to-length lines, stamping presses, roll forming equipment, pipe and tube mills, machine componentry, controls and electrical services. Companies represented by VMS include Coe Press Equipment, Stamtec, Bilsing Automation, HMS Products, Yates Cylinders and Kent Corporation; www.visionarymfgsolutions.com.
Technologies: Coil and Sheet Handling, Stamping Presses, Other Processes
There are no comments posted.Press-Feed Equipment
Tuesday, June 17, 2025
5 Questions About Air Feeds; 5 About Servo Feeds
Bradley Nordlof Thursday, April 17, 2025
Press Room Equipment Breaks Ground on New Facility
Friday, March 28, 2025
