Diamond Grinding and Cleaning Wheels Last 100 Times Longer than Resin-Bonded Wheels
May 1, 2011Comments
The EB Cluster wheels are designed to remove paint, rust and epoxy on metal, as well as high material removal on fiberglass, composites and plastics without loading up as do traditional abrasives. Available in 80 grit and disc sizes 4-, 4.5-, 5-, 6- and 7-in. dia., the discs’ light weight allows for high-rotation grinding with portable angle grinders. Maximum speed ranges from 8400 to 15,200 RPM, depending on diameter.
CS Unitec, Inc.: 800/700-5919; www.csunitec.com
See also: CS Unitec, Inc.
Technologies: Finishing
