Exchangeable-Head Milling System with Internal Coolant
July 1, 2013Comments
Sandvik Coromant, Fair Lawn, NJ, introduces the CoroMill 316 exchangeable-head milling system with internal coolant delivery, ideal for high-feed face milling, slot milling, helical interpolation, shoulder milling, profile milling and chamfer milling of components in material groups from ISO P to ISO S. Machining these heat-resistant superalloys, titanium alloys and stainless steels often requires the use of coolant for temperature control and chip evacuation during cutting. Recutting of chips and chip jamming often lead to poor surface quality, damage to the cutting edge and tool breakage.
By offering an internal coolant solution, with precise positioning of coolant holes to optimize the effect of the coolant jet, CoroMill 316 reportedly will outperform existing solutions using external coolant.
CoroMill 316 end mills are even suitable for five axis milling of flanks, which often require tapered tools for stability at longer tool reach.
Sandvik Coromant: 800/726-3845; www.sandvikcoromant.com
See also: Sandvik Coromant Company
Technologies: Finishing
There are no comments posted.Automated Finishing Cell for High-Mix Applications
Wednesday, November 20, 2024
Arku Sets Up Shop in South Carolina
Tuesday, September 17, 2024
