Flap Discs for Aggressive Stock Removal
February 26, 2020
Pferd showcased its Polifan Z SG Power Steelox flap discs for aggressive stock removal at FABTECH 2019, and announced the addition of a 6-in. (Type 29) disc in 40 and 60 grit, in 7⁄8-in. arbor and 5⁄8—11 hub versions. The new flap disc, like others in the product family, maintains consistent performance throughout its life, with its Zirconia alumina Z abrasive handling demanding grinding work and delivering optimum stock removal on high-powered angle grinders, even at higher contact pressures, according to company officials.
The line of flap discs is specified for use on steel and stainless steel, and reportedly excels in work on weld seams, chamfering, blending and deburring. And, the line provides reduced vibration, noise and dust levels.
Industry-Related Terms: Grinding, Grit, Stainless Steel, Abrasive
See also: Pferd Inc.
Technologies: Finishing
