Grinder Boasts Flexible Driveshaft
October 1, 2010 CS Unitec, Norwalk, CT, introduces its flexible-driveshaft grinder, finishing work on awkward pieces and in hard-to-reach areas. The flexible, easy-to-position shaft converts any industrial angle grinder with a 5⁄8 x 11 spindle into a lightweight, hand-held grinding/polishing tool. It’s ideal for use with the firm’s Multi-Max multipurpose grinding/polishing machine and the Varilex angle grinder. Accommodates 1⁄8- and ¼-in.-shaft abrasives and polishing rings up to 6-in. dia. (with mandrel). www.csunitec.com
See also: CS Unitec, Inc.
Technologies: Finishing
