Andritz to Supply Push Pickling Line for AHSS Grades to Ternium Facility in Mexico
December 19, 2022Comments
The Ternium steelmaking plant in Pesquería, Nuevo León, Mexico (near Monterrey), has ordered a new high-end push pickling line from Andritz, designed for advanced high-strength steel grades. The new line, with an annual capacity of 550,000 metric tons, will be used mainly to supply the automotive and home-appliance industries. Start-up is scheduled for mid-2024.
Andritz will supply the complete mechanical strip-transport equipment setup with precision leveler and automation packages, and provide process technology including high-turbulence hydrochloric acid pickling, and compact rinsing and drying sections specially designed for push pickling lines.
See also: Andritz Kaiser GmbH
Technologies: Materials
There are no comments posted. Materials
Daniel Schaeffler, Eren Billur February 8, 2024
Hot-Stamped Steel and Aluminum Drive Autobody Changes
