Rail-Guided Die-Change Table for Heavy Loads
July 30, 2024Comments
Roemheld North America
Booth S32051
Roemheld North America showcases its new rail-guided RWS mold-changing table for transporting heavy dies and molds, available in three versions for loads to 15, 25 or 40 tons per die. RWS answers today’s trend where loads in die and mold making are ever-increasing.
Electrically driven, the system is equipped with two different pull-push systems for safe, automatic transport of dies to setup presses. It can be used to change dies and molds on all types of machines, including those used for vertical forming and injection molding.
The die-changing table is guided on floor-level round rails with low rolling resistance that enables loads to 5 tons to be moved manually by only one person. In addition, the rails facilitate precise carriage guidance and prevent dirt deposits and tripping hazards in the floor. The RWS integrated pull-push system moves dies onto and off the press bed via the roller rails, and a safety mechanism ensures that the loads can only be moved when the RWS die-changing table is attached firmly to the press or the storage space.
RWS is available as a single or tandem cart and can be used flexibly in a range of production scenarios.
See also: ROEMHELD North America
