Autonomous and Manual Material Lift Trucks
July 26, 2024Comments
Combilift USA
Booth S26059
The Combi-AGT (pictured) is a four-wheel electric, stand-on, dual-operational—autonomous and manual—sideloader for long loads. With a lift capacity of 11,000 lb. and a lift height to 470 in., it addresses the requirements of steel service centers and the metal industries, which typically handle long loads.
Its design is based on the electric, manually operated Combi-GTE model, long a popular choice for service centers due to its ability to work efficiently in rail-guided narrow aisles. If laser-based sensors on the Combi-AGT, fitted at various positions on the chassis, sense an obstacle or pedestrian that has entered the truck’s path, the truck automatically slows down and, if necessary, stop. It then will continue to drive automatically when the obstacle has cleared its safety-sensor area. The enhanced, adaptive safety system enables the size of the obstacle-detection fields to increase or decrease as per the steer angle and speed of the truck.
Also from Combilift, the fully electric Combi-CB 155E. It is the shortest 15,500-lb.-capacity counterbalance truck on the market for its capacity and features exceptional maneuverability, according to company officials. Its compact size and its sideways movement capability make it easier to navigate through tight spaces and narrow aisles while transporting long steel billets and bars as well as other steel products such as coils, pipes, metal roofing, etc.
See also: Combilift Ltd.
